Nodes on an axis
Does anybody know if it is possible to get the nodes end theirs coordinates that were generated on an axis?
For example, the nodes that are encircled in the image below.
Thank you !
Kind regards,
Andrei
Hello. As a possible solution:
  1. Create a beam along the axis in a separate group
  2. Activate only it in Wingraf
  3. Go to the Nodes section → Display as list
  4. Export the resulting list of nodes to Excel with the RESULTS module
There are more advanced ways.
See also what Ragl says:
Thank you for your reply.
