I’ve created a geometry model in Sofiplus which I want to export to teddy. As far as I can tell, I need to do the following steps to get it into teddy:
In sofiplus: “Create calculation model” > “OK” > “Open sofistik” > “Database tools” > “Export to DAT”.
Is it possible to shorten this process, so I can export directly to dat from sofiplus? Or even better, access the information directly in the .dwg file using e.g. python?
I guess I can access the database in the cdb file and extract everything through there, but i’d rather not have to create the calculation model prior to extracting the data.
Sofiplus writes directly to the cdb, you can’t hijack the process
You can export cdb contents to dat (don’t forget to check the relevant boxes)
Since it’s a “build cdb” then “extract from cdb”, the text files aren’t always a 100% (there have been bugs)
If you really want to export geometry from a CAD software directly, you’ll probably have to write your own interpreter/parser.
Or perhaps you go for rhino.
I think the rhino plugin generates text files (could be mistaken)
you can not use the export.exe (via CMD) with the check boxes.
Alternatively you can use the context menu in the windows explorer. With a normal installation, this context menu will be installed as well and you can export the files directly without opening teddy or ssd.
You can use the command “expo” to export the input as well. As an example, I have attached a file for you.
Wonderful, I can work with this! thanks!
What I’m actually trying to do run the entire model through teddy, (keeping out of SSD).
My code would look something like this:
+prog aqua
head Materials
conc 1 c 40
stee 2 b 500
+prog sofimshc
head Geometry
#include geometry_MEX.dat # This would be the exported geometry from sofiplus
But maybe there’s a smarter way to do this?
Rather than having to include the exported file, perhaps it’s possible to include the *dwg. directly?
Perhaps one day there will be a script that opens the dwg.file and exports all defined informations from there into the cdb. But until now this is not possible.
