Warning no. 909 in Sofiload
I often experience warning no. 909 (loads activated with less than 100 percent) when I apply free loads in sofiload.
When I check the results I’m often hitting about 98-99% due to vertical alignments on road profiles. As such, I’m OK with this inaccuracy, but I don’t want to keep looking at the warning, so I turn it off.
however, I would prefer to be able to tweak when this warning is displayed, e.g. at 95% or similar.
Is this possible?
this is a good point, but not possible at the moment.
I will forward this for further discussion.
Cheers Martin
Any news on the the implementation of this feature?
Would it perhaps be possible to switch it off and on again?
Perhaps something along the lines of:
ctrl opt 'warn' val 909 v2 'off'
LC no 26 type 'sc_2' titl 'KL50 surcharge 2'
AREA ref 'qgrp' no 2 proj 'n' type 'pz' wide 50 x1 0.7 z1 36 p1 49 x2 1.3 z2 35.6 p2 49 x3 3 z3 32 p3 7.5 x4 -1 z4 32 p4 7.5
AREA ref 'qgrp' no 2 proj 'n' type 'pz' wide 50 x1 2.7 z1 36 p1 49 x2 3.3 z2 35.6 p2 49 x3 5 z3 32 p3 7.5 x4 1 z4 32 p4 7.5
ctrl opt 'warn' val 909 v2 'on'
Where v2 could vary between 0.00 and 1.00 or simply be on/off completely
