Warning no. 90497 in program Tendon: Duct geometry check TGEO: The distance to the element boundary: undercuts the minimal distance:
I have modelled the bridge girder using beam elements and the slab using shell elements. When I try to define the PT tendons in the cross-sections, I get the following warning:
+++++ warning no. 90496 in program Tendon: Duct geometry checkTGEO 11 is (partially) outside of the FE-Mesh. Protrusion: 0.000m (incl. duct).
My understanding is that the program may be treating the beam and shell elements as separate sections and checking the tendon geometry against each element type independently, rather than recognising them as one combined cross-section.
Is there a way to connect the beam and shell elements so that the program recognises them as one continuous section when checking the tendon geometry?
No, this is not possible. However, in this particular case, you can safely ignore the warning.
