Hi all,
I am struggling to fully understand the syntax for volume loading (VOLU) in Sofiplus. Despite multiple readings of Chapter 3.20 “VOLU - Volume Loading” in the Sofiplus manual, the syntax, particularly Figure 3.11, eludes me.
Could someone please explain how the syntax should be interpreted? I am especially confused about applying volume loads in the context of soil and water pressures.
I have created a small example model to illustrate my problem. So far, I have successfully applied volume loading for water pressure using the p, z, and p1 parameters. However, applying the same logic to soil pressure, especially with sloping retaining walls, has proven challenging.
Model description
Side 1 and 2 have dry soil covering their entire surfaces. Side 3 and 4 also have soil covering their entire surface, but have a water table at z = 7.
Dry soil density is 20kN/m3 while the effective soil density is 10kN/m2
- P = 0 at the top, and increases by 20kN/m2 downwards.
- P = 0 at coordinates (0, 0, 0) and (0, 10, 5), while increasing by 20kN/m2 downwards
- P = 0 at coordinates (0, 10, 5) and (10, 10, 10) while increasing by 20kN/m2 down to z = 7. from z = 7, it should increase by 10 kN/m2 instead
- P = 0 at the top increasing by 20kN/m2 down to z = 7. from z = 7, it should increase by 10 kN/m2 instead
So I guess it comes down to the two questions:
- Is it possible to at VOLU loading on a slope?
- What is the best way to change soil density along a line?
Please find the example model here:
+prog aqua urs:1 $ materials
head
NORM dc ds en199x-200x
UNIT 5
CONC no 1 c 40 ec 17500 gam 25
STEE no 2 type 'b' fy 500
CONC no 3 c 40 ec 20000 gam 25
+prog sofimshc urs:2 $ geometry
head
syst 3d gdiv 10000 gdir negz
ctrl opt mesh val 1
spt no 1 x 0 y 0 z 0
spt no 2 x 10 y 0 z 0
spt no 3 x 0 y 10 z 0
spt no 4 x 10 y 10 z 0
spt no 5 x 0 y 0 z 10
spt no 6 x 10 y 0 z 10
spt no 7 x 0 y 10 z 5
spt no 8 x 10 y 10 z 10
sar no 1 t 100 grp 1
sarb type out na 1 ne 2
sarb type out na 2 ne 6
sarb type out na 6 ne 5
sarb type out na 5 ne 1
sar no 2 t 100 grp 2
sarb type out na 1 ne 5
sarb type out na 5 ne 7
sarb type out na 7 ne 3
sarb type out na 3 ne 1
sar no 3 t 100 grp 3
sarb type out na 3 ne 4
sarb type out na 4 ne 8
sarb type out na 8 ne 7
sar no 4 t 100 grp 4
sarb type out na 4 ne 2
sarb type out na 6 ne 8
sarb type out na 8 ne 4
+prog sofiload urs:3 $ volu loading
head
lc 1 type 'none' titl 'Soil load 1'
volu ref 'qgrp' no 1 type 'pz' p 0 z 10 p1 -20
lc 2 type 'none' titl 'Soil load 2'
volu ref 'qgrp' no 2 type 'pz' p 0 z 10 p1 -20
lc 3 type 'none' titl 'Effective Soil load 1'
volu ref 'qgrp' no 3 type 'pz' p 0 z 10 p1 -20
volu ref 'qgrp' no 3 type 'pz' p 0 z 7 p1 10
lc 4 type 'none' titl 'Effective Soil load 1'
volu ref 'qgrp' no 4 type 'pz' p 0 z 10 p1 -20
volu ref 'qgrp' no 4 type 'pz' p 0 z 7 p1 10
Additional info
I have already contacted Sofistik support on a related question.
However, I believe a public discussion might be beneficial for many users dealing with similar issues.
Thank you in advance for any insights or suggestions.
