The first, intuitive test script produces a warning and a wrong result.
+PROG AQUA urs:1
HEAD
NORM DC EN NDC 199X-200X
CONC NO 1 TYPE C FC 30
+PROG SOFIMSHC urs:2
SYST TYPE 3D
CTRL MESH 1
CTRL HMIN VAL 0.5
SAR 1 MNO 1 NX 0 0 1 NRA 7 DRX 1 0 0 T 200 CB 0 CT 0
SARB OUT
SLNB R 20 XM 0 YM 0 ZM 0 NX 0 0 1
+PROG SOFIMSHA urs:3
SYST REST
GRP 'A'
SBOX A1X 0 A1Y 0 A1Z 0 B1X 0 B1Y 0 B1Z 1 R 21
SBOX A1X 0 A1Y 0 A1Z 0 B1X 0 B1Y 0 B1Z 1 R 15 OPT NOT
The second script with auxiliary secondary groups produces the right result but it is to verbose and pollute the project with the auxiliary secondary groups ‘A1’ and ‘A2’.
The logical operators of SBOX are known to be of limited use, especially when multiple SBOXes need to be combined. In your example, logical ‘NOT’ actually means ‘OR NOT’, and not ‘AND NOT’, as would be required to subtract the two selection discs.
For this reason, since SOFiSTiK 2020, we have a new set of logical operators for selections that are applied directly to groups / secondary groups. Please refer to section 3.9.2 of the SOFiMSHA manual.
So the solution to your question would be to use the following teddy input:
SYST REST
GRUP 'big' BEZ "Quads in SBOX"
SBOX a1x 0 a1y 0 a1z 0 b1x 0 b1y 0 b1z 1 r 30
GRUP 'small' BEZ "Quads in SBOX"
SBOX a1x 0 a1y 0 a1z 0 b1x 0 b1y 0 b1z 1 r 10
GRUP 'A' $ big - small = ring
quad 'grp' 'big' ! select big disc
quad '!grp' 'small' ! subtract small disc
ENDE
Apart from that: Why don’t you use attribute areas? That way you can change the SARs directly in SOFiMSHC.
SYST ART 3D GDIV 10000
STEU MESH 2
STEU HMIN WERT 0.5
SAR 1 MNR 1 NX 0 0 1 NRA 7 DRX 1 0 0 T 200 CB 0 CT 0
SARB OUT
SAR NR prop GRP 10
SARB out
SLNB R 10 XM 0 YM 0 ZM 0 NX 0 0 1
ENDE
