Dears,
So i have been working in modeling a structure inside grasshopper and then importing it to Teddy.
One issue I am facing is that I am trying to add nodal masses using (MASS) command in SOFIMSHA, but the defined and arranged nodes from grasshopper are under SOFIMSHC module.
so when ever I add the MASS command for a node number that is already defined in SOFIMSHC i get an error
+++++ error no. 2011 in program NR_CHK_MASS ; input line: 87
Node number 5502 is not defined
I wonder if there is a way to “import” these SPT number to SOFIMSHA and use them there? I have looked around and only found a way to import different database
Thank you
