I’m using unit set 6 (dimensions mm, forces kN). In my model, I have elastic rotational support and I was wondering which unit the rotational spring stiffness is in. Using a simple test model I found out that the spring stiffness is in kNm/rad where I was expecting it to be in kNmm/rad as in the SOFIMSHA manual it says that it is an implicit unit with ID 1100. And for an implicit unit I would expect the length to change according to the unit environment.
In the cdbase.chm I found the list of the unit IDs and how they are defined in the CDBASE and what is the default, but what I really would like to have is a table of all unit IDs and see how they are actually defined in each unit environment. Does anyone know where to find such a table?
Joachim
