Turn off bedding in Teddy in area elements
Hi!
I need to consider two cases in my area element in calculation. Firstly, It is the case with assigned bedding (assigned in the Sofiplus) and second one without its. And is it possible to deactivate this assigned bedding in Teddy in ASE before calc? Can I add some record in Teddy which can turn off it in this case??
I do not want to create separated case without bedding and other group and complicated this. I know it is possible to deactivete springs/element etc but I need deactivate only bedding in area element.
Regards, Andrzej
Hi Andrzej,
with GRP .. FACB 0 in ASE you can turn off the bedding of QUAD elements.
Best regards, Nora
