I have ran different simulations in parallel (each on a different .DAT file, a different .CDB is generated).
The system is 100% the same, but the dynamic loads are different.
For each of the files, I have obtained the envelopes using MAXIMA, and now I need to combine these results into one single .CDB, with an “envelope of the envelopes”.
I’ve tried copying the LC envelopes using PROG DBMERG, but I always get in return: “load case 653002 not allowed - error no. 10 in program DBMEIN”. Below is my an example of DBMERG code:
And this is repeated for all my individual simulations. Also, to clarify: I’m able to copy standard load cases generated, for instance, with ASE. I just cannot copy load cases generated from MAXIMA.
