I have a problem in my Sofistik model. I have modelled my structural areas of both walls and slabs based on points with SARB NA NE, but when I create the mesh, it seems that the wall and slabs disconnect near edges. However i have also tried modelling the areas based on lines. In this case, the area and walls are connected
Created SPT’s for the wall (with a number)
Used the SPT’s to create the wall SAR
Created SPT’s for the slab (with a number different from the wall)
Used the SPT’s to create the slab SAR
The result is:
Defining SPT’s in the same location twice → two nodes in the same location that are not connected.
Referencing the SARB to different SPT’s → two boundary lines that do not intersect (structurally)
What you should do:
Create SPT’s
Do not create more than one at an intersection
Reference both the wall and the slab SAR to the same SPT
Maybe check out the following example in your installation folder:
C:\Program Files\SOFiSTiK\2020\SOFiSTiK 2020\sofimshc.dat\english\area_models\separated_slabs.dat
