I am making with Teddy buckling calculations of bowstring archs, with cables elements between arch and deck. I was wondering if sofistik takes into account the tension of the cables (in the case of using prestessed cables) in the buckling calculation.
Thank you in advance.
if you made th3 analysis and use sfix ...
in buckling case, then yes, it take into account
