We know that for post-tensioned members, before tendon grouting, the net section is used; while after grouting, the transformed section is used.
So the section properties before and after grouting are different, therefore the stresses are different too.
But in CSM manual $2.4,
All construction stages that cause changes of stresses have to be considered. Therefore
construction stage grouting / extrusion (CS: x2) is not necessarily to be computed, due to the
fact that the grouting mortar causes no changes in stresses.
I guess it is noticed there that grouting itself does not case any loads, so if cs:x2 stage is not calulcated it is no problem, but after cs:x2 stage brutto section properties are used.
This is the official Sofistik Verification Example:
DCE-EN17: Stress Calculation at a Rectangular Pre-stressed Concrete CS
verification.dat\dcbenchmarks.dat\dce-en17\stress_prestress.dat
I add “CSM” in it.
At mid-span of the beam:
Hand calculation & AQB:
dead load moment = 1250 kNm
prestressing moment on net section (before grouting)= -1435.91 kNm
prestressing moment on transformed section (after grouting) = -1406.11 kNm
on net section, moment = 1250-1435.91 = -185.88 kNm, the bottom stress = -4.82 MPa
replied to my self
The stress in transformed section in CSM is correct, because the stress before grouting is “locked in” the structure, it won’t change after grouting.
I think so.
In Sofistik official verification example:
C:\Program Files\SOFiSTiK\2025\SOFiSTiK 2025\verification.dat\dcbenchmarks.dat\dce-en17\stress_prestress.dat
I made 2 changes:
set ECC in Tendon from 9.9 to 0
add CSM as shown below
!#!Chapter
CSM
head
CTRL
DL
NO
CS
NO
TYPE
11
P
12
20
GRP
NO
ICS1
10
11
'+apply $(NAME)_csm.dat
In the original dat file, CS11 is prestressing, CS12 is grouting. I add CS20 in the CSM, I hope brutto (transformed) section properties used in CS20 according to “but after cs:x2 stage brutto section properties are used.”.
This is the stress results
The left is AQB load case 100 (CS11), the right is CSM CS11, both use net section, the stresses are the same
