I’d like to change a few feature of a model created in SofiPlus using Teddy, but I’m encountering problems with variables.
When run the file obtained from export.dat I can’t see the variations in the sectional shape I set in Sofiplus. Not even if I merge it with the one with tasks, as indicated online. Also, reading the AQUA script for each interpolated section I see that variables have the correct value. Did anyone had this problem before and know how to fix it?
I usually don’t use parameterized sections, but to understand your problem, I created a small example. A very strange thing is that the structure exported from SOFiPLUS gives one result, but if you export it to a .dat script and run it, you get a different result. This is beyond my understanding.
Perhaps someone more experienced will clarify the situation, or something is wrong with the export
It surprised me as well, maybe some overwriting? But I can’t find it.
Anyway, thank you for your attempt Kirill. I hope more experienced users will help.
Hi sfr! Thank you for your advice and time. I see now, I’ll try to see if a similar lock is being set up.
I agree with you, coding would be best, as for the analyses I need to do I can’t work directly.
Do you think that using Rhino and GH could present similar problems or is the integration smoother so that it is worth spending more time on geometry setting there?
Anyway, thank you again,
Giorgia
