I am running a large number of simulations, each of which having its own unique ID. I’ve defined a variable which contains this ID, which is used for some calculations of other variables:
sto#simulation_id 185
After each simulation, I also write the acceleration data into a file with the ‘DUMP’ item of the ‘HIST’ record in the ‘DYNR’ program, as well as a .txt file which contains some other values. The names of these files should contain the simulation ID, as can be seen below.
HIST LCS 801 TYPE A-Z NO0 #node_neighbor C0 1001 DUMP Simulation185
<TEXT,file=Quantities_simulation185.txt>
This works fine like this, although it requires me to manually replace the ID at 3 places every time I run a new simulation (the value of the #simulation_id variable, the HIST record and the name of the .txt). I’d like to know if there’s a way to use the variable to create the correct names for the latter two records somehow, so that I only need to change the ID once per simulation. I’ve already done some tests with a second variable #simulation_name, but this doesn’t seem to work.
Any advice is very welcome!
