I was wondering if it’s possible to define end conditions for lines in a separate group which can later be controlled in CSM ?
I mean,
SLN 1 NPA 1 NPE 2 FIXA MM FIXE MM GRP 2
works, but I would like to remove the moment hinges from both ends of the line in a later construction stage and have integral connections with other lines.
Usually if there was a gap between this line and adjacent lines, I would create a link between the two points using SPTS and give different groups for each spring and activate them at various CSM stages, but I was wondering if it’s possible to directly define a hinge at beam ends as it is and later remove it in CSM ?
I was under the impression SPTP is used to define fixities (like supports / rigid links) and cannot be used to define hinges (or release of moments).
Could you please explain a bit more ?
Say I have 3 lines -
SLN 1 NPA 1 NPE 2
SLN 2 NPA 2 NPE 3
SLN 3 NPA 3 NPE 4
By default, the lines are connected at a single point so that point is fully rigid. How do I create a hinge at both ends of line SLN 2 such that I can deactivate them later in CSM ?
