Stiffness value K For Column
Hi
I’m working on developing an equivalent cantilever model with timber material for high-rise timber building. I am trying to understand how to give the stiffness K to all columns in teddy Script. i can’t find proper input text in teddy to give values of K can anyone please help me with this ?
For more specific you have a look at teddy model
Equivalent_cantilever_model.dat (1.6 KB)
What do you want to achieve?
I am not sure if your project can be implemented. But you can look at the following commands, maybe they will help you.
  • You can reduce the stiffnes of a group in ASE with the command GRP2.
  • Apart from that you can create a general matrix element with the command ADD in SOFiMSHA.
  • Create a general elastic element with the command FLEX in SOFiMSHA.
Thank you
