Got a regular steel profile (I 320) reinforced by two thin sheets of steel (100x10) welded on the upper and lower belt of the profile, respectively. How to model?
First try fails for the reason, that thin and thick is not allowed together:
QNR 53 MNR 2 ZSYM NEIN
PROF NR 1 TYP I Z1 320
BLEC NR 2 YA 50 ZA 165 YE -50 ZE 165 D 10
BLEC NR 3 YA 50 ZA -165 YE -50 ZE -165 D 10
Hello blackbird,
it is possible to reinforced steel profiles with sheets.
Therefore it is necessary to define a thin-walled profile with PROF …. DTYP D.
The sheets have to be connected for shear to the profile with LNAH → shear connection. These connections are only possible at a beginning or an end of a sheet.
I have modified as an example your input:
PROF NR 1 TYP I Z1 320 DTYP D
BLEC NR 2 YA 50 ZA 165 YE 0 ZE 165 D 10
BLEC NR 3 YA 0 ZA 165 YE -50 ZE 165 D 10
LNAH NR 11 YA 0 ZA 165 YE 0 ZE 151.3
BLEC NR 4 YA 50 ZA -165 YE 0 ZE -165 D 10
BLEC NR 5 YA 0 ZA -165 YE -50 ZE -165 D 10
LNAH NR 12 YA 0 ZA -165 YE 0 ZE -151.3
Dear Sabine,
thanks a lot for the fast answer. The DTYP D option for PROF helps a lot. The shear connection is a valid point. For realistic representation I have to account for the welding at the left and right side of the sheets. Therefore it remains a single sheet on the upper an lower side with two LNAH at the edges, respectively. However I struggle with finding the z-coordinate of the profile to connect the end of it correctly … Do you know how to find the value. So far I got
LNAH NR 11 YA 50 ZA 165 YE 65.5 ZE 151.3
LNAH NR 12 YA -50 ZA 165 YE -65.5 ZE 151.3
LNAH NR 13 YA 50 ZA -165 YE 65.5 ZE -151.3
LNAH NR 14 YA -50 ZA -165 YE -65.5 ZE -151.3
Ich versuche es mal als Amsel:
Die LNAH-Z-Koordinaten zu den Profilpunkten stimmen nicht ganz. Wenn man sich die Profil-Dünnwandteile und deren Koordinaten anschaut (ECHO QUER EXTR in AQUA), ergibt sich, dass die Gurtenden bei Höhe 153,6 (statt 151,3) liegen.
Das funkioniert: qnr 53 mnr 2 bez ‘I320 verstärkt’
NR 3 YA = ZA -165 YE = ZE -165 D =
lnah G1a YA 50 ZA 165 YE 65.5 ZE 153.6 d 3 $ Gurt 1
G1b YA -50 ZA = YE -65.5 ZE = d =
lnah G2a YA 50 ZA -165 YE 65.5 ZE -153.6 d = $ Gurt 2
G2b YA -50 ZA = YE -65.5 ZE = d =
Dann muss man sich bei Bedarf nur noch Gedanken um Blechbeulen (c/t) der Gurtzulagen machen :- )
Real würde man die Zulagen eher direkt am Zulagenrand auf das Profil brutzeln (und nicht mit Nahtdicke 10).
Super, das klappt. Mit der Ausgabe aus ECHO QUER EXTR kann ich das Profil aus Einzelblechen aufbauen und an der entsprechenden Stelle dann noch Ober- und Untergurt teilen. Damit stimmt auch der Ansatz der Schweißnaht:
