I manage to open the correct file in SSD, the only thing I’m missing is pressing the “Calculate All” button in the top, but that sort of defeats the purpose.
So, is it possible to run the calculation through cmd in SSD?
I recommend to “Save All Tasks As Text…”, reachable in SSD under “File”. Then you can start calculation of this dat-file via SPS.
Perhaps this helps(?)…
Regards,
Jost
Everything is saved as text. My python script generates a huge *.dat file with hardcoded teddy functions for sps to read.
Then in the end of my python script I use subprocess.run() to run sps through batch and point to the generated *.dat file.
The only issue is the limited visualization in sps, so I’d much prefer the WPS/SSD window to pop up so I can see the iteration graph, load case number, run time etc.
I was not aware of the possibility of a macrorecorder-session and can’t seem to find it in any of the sofistik manuals. Where can I read documentation of this?
