Spring - Work Law - Non linear analysis
In a nonlinear analysis, springs work only in tension (no compression).
For it to work, you need to set a behavior law that operates in both compression and tension, so that in a nonlinear analysis, the spring functions in a single direction, which is ideal for soil-structure interaction.
