I’m working on the design of a pile and have defined the interface between the pile and the soil using springs with a force-displacement law. The type is set to a P in module in AQUA.
I then defined springs in the X and Y directions in SOFIMSHA, using the work law specified in AQUA.
After applying a force in the X direction at the center of the pile cap, I ran a non-linear analysis, but the system became unstable. However, when I ran a linear analysis, it worked well.
I also tried using PT in the definition of the work law, and while it worked correctly in both the X and Y directions, I noticed a reaction in the Z direction (although the values in the Z direction are very small).
Has anyone worked on a similar project and could provide feedback or share how they addressed this issue?
