The Aqua.dat is attached:
Aqua.dat (6.5 KB)
Below is the result from Sofistik 2020:
Below is the errors from Sofistik 2022:
Project data base Aqua.cdb - 1. access
+++++ warning no. 12286 in program SOF_INP_MSTEEL ; input line: 11
Material 2 has a class which is not known in the tables of the program
This is allowed for historical or damaged materials, but an explicit
definition of the intended strength values is then strongly recommended!
+++++ warning no. 2257 in program PO_DQP ; input line: 70
Coordinates have zero distance - cross section 1
+++++ warning no. 2257 in program PO_DQP ; input line: 138
+++++ warning no. 137 in program AQTOVA
Very short strokes in polygon in cross section 1
please check accuracy of It and shear center
+++++ warning no. 321 in program AQTOVE
Cross section 1 is not connected for shear, check shear center
Principal Reasons are panels or polygons not properly connected.
+++++ warning no. 35 in program AQU_SVAL
The plastic section capacity for section 1, construction stage 0 is calculated for a composite section
(EN 1994-1-1, ch. 6.7.), although the steel content is δ > 0.9 ( 0.99)
+++++ error no. 328 in program AQUTOR
Cross section 1 has numerical problems with Integral Equations
Please check first if the outer contour is properly detected by specifying
CTRL SDIV 0 and ECHO IEQ. Then try to increase CTRL SDIV.
If everything fails, you may deactivate this analysis method (CTRL STYP 0)
+++++ error no. 326 in program AQUTOR
Cross section 1 the calculated It is larger than Ip = Iy+Iz
Reason might be to differences in length of polygon edges
please have a look at the warping distribution via Result Viewer
