I’m trying to debug a model I’ve written up in Teddy.
When I define a SPT, I can only see it in Wingraph after I’ve attached a SLN with a SNO to it. Is this really true?
SOFiMSHC deletes structural points and lines which are not connected with the model and which have no stiffness properties.
Try to change the setting for the program SOFiMSHC with the command “CTRL DELN 0”.
Further information can be found within the SOFiMSHC manual.
SSD / TEDDY > Help > User Manuals > All Manuals… > sofimshc > chapter “3.5 CTRL - Control of analysis”
Thanks, it works to an extent, but I still need to attach an SLN to the SPT in order to see the point, but I no longer have to apply an SNO to the SLN.
