SIR cut graph with connected (smooth) values
I would like to present bending moment from External Beam Section (SIR) as a connected graph, instead what i get is values sequence along the beam.
It only happens when i create SIR cuts through loops in teddy, when SIR’s are created in wingraf - values in plot are connected (smooth)
Whats the solution?
It seems that you have generated the SIR-cut only at the start of each beam at x=0, and since the end of each beam (talking about FE-beam not the whole static beam member) is missing, the result consist of only single values at the start of each beam. Take a look at the syntax you use for SIR and assure x hasn’t been set to 0 only.
