Good morning,
I have a question regarding settlement load application. A window picture of the model is posted below.
The superstructure is modeled together with piers, a foundation plate, and a deep pile foundation. The bridge superstructure beam nodes are coupled with springs, which connect this assembly directly to the piers. Therefore, the springs serve as the load-bearing elements. The pier is coupled with the foundation plate, which in turn is connected to the piles supported by springs (for defining base resistance).
In a situation where the superstructure is modeled with the foundation, what is the best way to account for settlement loads in different axes? In conventional models with separate superstructures and normal load-bearing elements, it is possible to directly apply node deformations (e.g., KNOT TYP WZZ 20). However, in this specific case, I cannot find a good alternative for that.
Thanks in advance.
Grüße,
Lucas
