I am trying to access the cdb from python. My goal is to read the self-weight values. They are stored in the record 18/LCD (see the screenshot below).
Why does the record contain several load values pval[0], pval[1], β¦ ?
Why not just a single value that correspond to the self-weight of the element?
In order to display the used self-weight in the Graphic correctly, the program needs the values of the self-weight at the start, at the end and the position of these values.
PVAL[0] β start of the section (related to the observed beam)
PVAL[1] β length of the section
PVAL[2] β self-weight at the start
PVAL[3] β self-weight at the end
You must provide multiple values because a beam can have two cross-sections, resulting in a changing self-weight.
