I am trying to make a simple model - a slab on pinned line supports loaded with the self weight, see the code below.
+PROG AQUA urs:1
HEAD SELF WEIGHT TEST
NORM DC EN NDC 199X-200X
ECHO FULL
CONC NO 1 TYPE 'C' FCN '25' GAM 0
+PROG SOFIMSHA urs:2
HEAD SLAB
SYST TYPE '3D' GDIR NEGZ
NODE 1 X 0 Y 0 Z 0
NODE 2 X 10 Y 0 Z 0
NODE 3 X 10 Y 10 Z 0
NODE 4 X 0 Y 10 Z 0
NODE NO MESH X 1 Y 2 DIV 10 FIX 'PP'
NODE NO MESH X 2 Y 3 DIV 10 FIX 'PP'
NODE NO MESH X 3 Y 4 DIV 10 FIX 'PP'
NODE NO MESH X 4 Y 1 DIV 10 FIX 'PP'
UMSH TYPE QUAD HMAX 0.5
UBND TYPE OUT SEL NODE N1 1 N2 2 N3 3 N4 4
+PROG SOFILOAD urs:3
HEAD SELF WEIGHT
LC 1 FACD 1.0 TITL 'SW'
+PROG ASE urs:4
HEAD SELF WEIGHT CALC
LC 1
The model is generated successfully, see below, but the self weight is not applied. What is wrong?
