hello
I wanted to know if I could select quads and put them in a group on sofistik with teddy
thank you
This is possible. Please have a look at the commands GRP in sofimsha (or sofimshc).
SSD / TEDDY > Help > User Manuals > All Manuals… > sofimsha > chapter 3.9 GRP - Group Control
Or you could have a look at the next TEDDY example.
TEDDY > File > Examples > sofimsha > english > secondary_groups_01.dat
it’s possible to select by quad number ?
best regard
grp “GSEL”
Quad ‘==’ NO 14303
Element 14303:
grp “GSEL”
Quad NO 14303
Or
Element 14303-14310
grp “GSEL”
Quad NO 14303,-14310
Sofimsha manual chapter 3.9.2:
You can also do it in sofimshc if you prefer working with structural areas
Thank you it worked
can i see subgroups on sofistik system visualization because it displays only groups ?
Seems like you did not manage to produce the secondary group(s).
Double check in wingraf/graphics. If it doesn’t show up in the group selection there, then you haven’t been succesful
