Dear All,
Is there any way to define mass “eccentric” from the cross section ?
Indian codes (IRC-6) states that the mass of live load shall be 1.2m above the carriageway – Hence seismic force due to live load mass shall also act at the same level (which is significantly above the CG of deck cross section).
Is there any way to achieve this directly in sofistik ?
There is a workaround (which is to manually calculate the liveload mass * acceleration * extra lever arm and apply it as a static load) but is there a way by which sofistik can handle it automatically ?
Warm Regards,
Aravind.
