Secondary groups
Hi
I’m using secondary groups to manage loads and views in my 3D model.
However, I’m experiencing an issue with viewing my groups in the system visualization.
Please find a test code here:
 +prog aqua urs:19.1
 head materials
 CONC NO 11 C '40' FC 40 EC 35000 GAM 25
 +prog sofimshc urs:19.2
 head Geometry
 SYST 3D GDIV 100000 GDIR NEGZ
 CTRL MESH 1
 loop#i 4
     SPT 11+#i*10    X 0+#i*1000 Y    0 Z 0
     SPT 12+#i*10    X 0+#i*1000 Y 1000 Z 0
 endloop
 loop#i 3
     SAR 1+#i MNO 11 t 100
         SARB NA 11+#i*10 NE 12+#i*10
         SARB NA 12+#i*10 NE 22+#i*10
         SARB NA 22+#i*10 NE 21+#i*10
         SARB NA 21+#i*10 NE 11+#i*10
 endloop
 GRP NO 'grp1'
     SAR 1
     SAR 3
If I try to watch the secondary group in system visualization, I only see one of the SARs along with a single mesh element?
However, if I open Graphic, and pick the secondary group in there, and use the “Settings from Graphic” in system visualization, I see the group as it’s supposed to.
The loads are applied correctly.
Are anyone else experiencing this issue?
Thank you for the inquiry. I have forwarded the case to the responsible developer.
As soon as we find a solution, we will inform you about it.
Please excuse me for reviving this post, but as this was where I originally reported the issue, I figured I’d just do it here again. If I should direct my inquiry elsewhere, please let me know.
I am experiencing similar problems in Sofistik 2023 with secondary groups yet again. This time only periodic, meaning that the issue may or may not present itself from run to run.
Using the old code from this thread I’m creating a secondary group using BBOX:
+prog aqua urs:19.1
head materials
NORM DC EN 199X-200X G 9.81
head Geometry
CTRL MESH 1
unit 6
loop#i 4
endloop
loop#i 3
endloop
GRP 'GR1'
    BBOX xmin 0 xmax 3000 ymin 750 ymax 1000
$    BBOX xmin 0 xmax 3000 ymin 0 ymax 250
This yields following graphics in the animator:
but this in wingraf:
When I use “Settings from Graphic” in the animator it shows correctly:
