SAR defined by SPT with different thickness at each point
How can I model a SAR with different thickness at each point. I cannot assign an unique thickness at the SPTs (and defining afterwards a null thickness at the SAR command) because the SPT’s are shared by different SAR’s
Hi david,
this is actually not possible.
Possible workaround: the edge of the other SAR is defined at a distance of e.g. 2 cm and the edges of both SARs are coupled.
Jost
