I am trying to get Eigenvalues from the high rise timber structure. I have given fixed support condition in bottom nodes but still i am getting follwing error. [254 rigid body modes in the system ,Please check if all parts of the structure have sufficient constraints despite of the type of loading ! (e.g., beams with hinges for torsion)Equations concerned are]. how do i fix this error? i have attched teddy file also if anyone can fix this error it will be very helpful
A short check of your system shows that all of the edge beams are not connected with the system. Please connect them to the structural areas and / or to the columns.
FE elements are only connected correctly if they share the same nodes. The visualised cross-section is completely irrelevant for the connection of the components.
