Hi all.
I’d like to ask is it possible to return from database a set of nodes within structural line according to the SLN number.
I’m modelling piles and I’d like to assign a different springs along the SLN (let’s say per 1m) depending on the soil conditions.
I know you can do this in a few different ways but for my purpose I’d like to try this approach.
I’m working in SOFIMSHC.
I create parametrized array of piles with variable number of piles, lengths, rows number, spacing etc.
To begin I create a loop which creates top SPT of the pile, and then the bottom - I have full control of SPT number here.
After all I generate in loop SLNs which links top SPT with bottom and give SNO and SDIV for the pile division (1m) and here I do not control node numbering.
LET#DX (#OF1-#OPP1)
LET#NR 2150
LET#POSX #DX
LOOP #NRP1
SPT NO #NR X #POSX Y 0 Z #H1
SPT NO #NR+1000 X #POSX Y 0 Z #H1+#LP1
LET#NR #NR+100
LET#POSX #POSX-#RP1
ENDLOOP
LET#DXX (#DX+#SXP1)
LET#LOOP ((#NP1-1)/2)
LET#NR1 2151
LET#POSX #DXX
LET#POSY -#SYP1
LOOP #NRP1
LOOP #LOOP
SPT NO #NR1 X #POSX Y #POSY Z #H1
SPT NO #NR1+1000 X #POSX Y #POSY Z #H1+#LP1
SPTS CP #CP_P1 CQ #CQ_P1 GRP 110
LET#NR1 #NR1+1
LET#POSX #POSX+#SXP1
LET#POSY #POSY-#SYP1
ENDLOOP
LET#NR1 #NR1+100-1*#LOOP
LET#POSX #POSX-#RP1-#SXP1*#LOOP
LET#POSY #POSY+#SYP1*#LOOP
ENDLOOP
LET#NR2 2149
LET#DXX (#DX-#SXP1)
LET#POSX #DXX
LET#POSY #SYP1
LOOP #NRP1
LOOP #LOOP
SPT NO #NR2 X #POSX Y #POSY Z #H1
SPT NO #NR2+1000 X #POSX Y #POSY Z #H1+#LP1
LET#NR2 #NR2-1
LET#POSX #POSX-#SXP1
ENDLOOP
LET#NR2 #NR2+100+1*#LOOP
LET#POSX #POSX-#RP1+#SXP1*#LOOP
LET#POSY #POSY-#SYP1*#LOOP
ENDLOOP
LET#NR 2150
LOOP #NRP1
LET#N (#NP1-1)/2
SLN ((#NR-#N) (#NR+#N) 1) ((#NR-#N) 1) ((1000+#NR-#N) 1) SNO 10 SDIV 1 GRP 510
LET#NR #NR+100
ENDLOOP
SLN number coresponds to top SPT number. Instead of making a loop for “each level” of SPTS according to pile division and then creating tons of SLNs, I’d like to get from database list of nodes number for SLN number specified by me - then export it to excel, put there my spring coeficients and use it for calculation.
I assume if I could get beams NR for the specified SLN (or just beams for specified GRP number), then get end node of these beams it would be what I want.
