Is it possible to get a return value from the database? I want to use the value (Center of gravity from the cross section from AQUA or a stress point) and implement it in my further code.
Thanks in advance!
Thanks in advance!
Yes, it is.
You can access the centre of gravity for cross section 10 in teddy as follows:
@Key Sect 10
Let#y_coordinate @(ys)
Let#z_coordinate @(zs)
You are accessing the database, so that you can access the values after they are written to the cdb.
→ The values exist in the cdb after the aqua run for the cross section
If you want more information, check out:
https://www.sofistik.com/documentation/2023/en/cdb_interfaces/cadinp/_cadinp.html
