I have run multiple analyses in ASE in Teddy, and I would now like to produce multiple plots of internal forces in Wingraf (in Teddy) based the previous database files. Does anyone know how to refer to an existing cdb-file in Teddy? Should the reference to the cdb-file appear inside or outside the Wingraf module?
You can address a database with the input DB in PROG WING, for example
DB NO 1 TITL 'C:\path\to\database1.cdb'
QUAD MY RESULTS FROM DB 1
DB NO 2 TITL 'C:\path\to\database2.cdb'
QUAD MY RESULTS FROM DB 2
See the manual “wingraf_1.pdf” in your installation folder.
I have tried a simple test but it still does not work?
+PROG WING urs:61
HEAD Test
DB NO 1 TITL C:\Users\JAGP\Desktop\Test\database1.cdb
You have to quote the argument of TITL
. Try
DB NO 1 TITL 'C:\Users\JAGP\Desktop\Test\database1.cdb'
and see if it works.
It still does not work. I get the same errors.
I just noticed that the correct parameter is not NO
as stated in the manual, but NUMB
So try
DB NUMB 1 TITL 'C:\Users\JAGP\Desktop\Test\database1.cdb'
If the teddy file is in the same folder as the cdb you don’t need the entire path, e.g.:
DB Numb 1 Titl 'database1.cdb'
Thank you very much. It works now
