I have a model where I am running LM71 load trains on two tracks simultaneously using ELLA module. When i check the longitudinal force, I get a load which is equivalent to maximum of braking/traction x 2 (for 2 tracks) x pfac (1.21).
But as per latest eurocode, you have to reduce the longitudinal load to half on one track. or you have to consider full braking on 1 track and full traction on another. Iam not sure how to implement this in TEDDY? Can someone please help me in understanding this. Thank you ![]()
In this case you must use different CASEs with different load trains, for example:
- CASE 1 with two load trains with half values for breaking
- CASE 2 with two other load trains with full braking and full traction
By the way: P8 im LM71 can be braking and traction, see SOFiLOAD manual chapter 5.5 and screenshot.
