Hello everyone,
I am referring to the example " Single span girder". It can be found using the following link:
The marked line of code is not clear to me. Why are we testing that beam id equals 0?
Thank you in advance!
Hello everyone,
Because the first two records are the max/min values of all beams and the beam id for these is 0.
Generally you need to loop through a record (e.g. 102/1001) line by line until you find what you want.
If you were looking for a specific beam section you would use that id instead.
However I think it should be changed to 0, since the beam id is an integer not a float
You can check what is in the cdb by going to:
Home → Database tools → Database Information
Also check out the CDBASE help: Help → CDBASE Help
Thank you for the response. It helped me understand the issue.
One more point: Why was that last parameter of the function py_sof_cdb_get() set as 1 in the above mentioned example?
Here you have to check the actual c/c++ functions in the cdbase help manual.
The last input for sof_cdb_get() is the position and a value >0 retrieves the next value in the database.
