Hi all
I’m trying to read data in two different Excel sheets. The programm has to loop over data in the first Excel-Sheet and for each item loop over another Excel-Sheet.
Is that possible? I could imagine that it doesn’t work because of the function XLS.IER that is the identical for the two loops. I tried with the variable J for the second loop but it is not solving the problem.
Here is my code below. I obtain Error Nr. 12110.
Thank for your help.
Nathan
+PROG TENDON urs:16
KOPF Hüllrohrgeometrie definieren
!*!Label 1. Systemwerte für das Spannverfahren
LET#XLS.SHEET "NachVerb_HuellroMaster_lsn"
LOOP#I
$ Variablen
LET#Bez0 XLS.READ(2+#I,1)
LET#HuellroID XLS.READ(2+#I,2)
LET#SpVerfahrenID XLS.READ(2+#I,4)
#define Bez=#Bez0
IF #XLS.IER<3
SGEO NRG #HuellroID NRH V11 NRSV #SpVerfahrenID ELEM axes BEZ $(Bez)
LET#XLS.SHEET "110"
LOOP#I
LET#Station XLS.READ(2+#I,5)
LET#Y XLS.READ(2+#I,6)
LET#Z XLS.READ(2+#I,7)
IF #XLS.IER<3
ZPUV TYP REFX S #Station U #Y V #Z ! DVS - DL - DR - RV -
ENDIF
ENDLOOP #XLS.IER<3
ENDIF
ENDLOOP #XLS.IER<3
ENDE
