So after running the ‘read_nodes.py’ code Sofistik has as an example, i tried replacing the database they gave as an example with my own. Unfortunately, now the while loop exists after 1 pass.
CDB Status: 1 (instead of 3)
and ie.value will be 3 after the first pass through the while loop.
Below you will find a picture of the database and the code. I also tried other databases but that didnt work either.
I am using the 2024 version, have an educational license and use python3.11 if that is important.
If any of you have an idea what the problem/my mistake could be, any help would be greatly appreciated
# | Company: SOFiSTiK AG |
# | Version: SOFiSTIK 2023 |
# import all types from sofistik_daten.py, original file can be found by following
# --> examples/python/sofistik_daten.py
from sofistik_daten import *
import os # for the environment variable necessary
import platform # checks the python platform
from ctypes import * # read the functions from the cdb
## This example has been tested with Python ...?
print ("The path variable=", os.environ["Path"])
# Check the python platform (32bit or 64bit)
print ("Python architecture=", platform.architecture())
sofPlatform = str(platform.architecture())
# Get the DLLs (32bit or 64bit DLL)
if sofPlatform.find("32Bit") < 0:
# Set environment variable for the dll files
print ("Hint: 64bit DLLs are used")
# Set DLL dir path - new in PY 3.8 for ctypes
# See: https://docs.python.org/3/whatsnew/3.8.html#ctypes
os.add_dll_directory(r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\interfaces\64bit")
os.add_dll_directory(r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024")
# Get the DLL functions
myDLL = cdll.LoadLibrary("sof_cdb_w-2024.dll")
py_sof_cdb_get = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_get
py_sof_cdb_get.restype = c_int
py_sof_cdb_kenq = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_kenq_ex
else:
# Set environment variable for the DLL files
print ("Hint: 32bit DLLs are used")
os.add_dll_directory(r"C:\\Program Files\\SOFiSTiK\\2024\\SOFiSTiK 2024\\interfaces\32bit")
os.add_dll_directory(r"C:\\Program Files\\SOFiSTiK\\2024\\SOFiSTiK 2024")
myDLL = cdll.LoadLibrary("cdb_w31.dll")
py_sof_cdb_get = cdll.LoadLibrary("cdb_w31.dll").sof_cdb_get
py_sof_cdb_kenq = cdll.LoadLibrary("cdb_w31.dll").sof_cdb_kenq_ex
# Connect to CDB
Index = c_int()
cdbIndex = 99
# input the cdb path here
fileName = r"...\read_nodes.cdb"
# important: Unicode call!
Index.value = myDLL.sof_cdb_init(fileName.encode('utf8'), cdbIndex)
# get the CDB status
cdbStat = c_int()
cdbStat.value = myDLL.sof_cdb_status(Index.value)
# Print the Status of the CDB
print ("CDB Status:", cdbStat.value)
pos = c_int(0)
datalen = c_int(0)
a = c_int()
ie = c_int(0)
datalen.value = sizeof(CNODE)
RecLen = c_int(sizeof(cnode))
do while ie == 0, see cdbase.chm, Returnvalue.
= 0 -> No error
= 1 -> Item is longer than Data
= 2 -> End of file reached
= 3 -> Key does not exist
while ie.value < 2:
ie.value = py_sof_cdb_get(Index, 210, 0, byref(cnode), byref(RecLen), 1)
######print(ie.value) -> 3
print("{:10d}{:10d}{:10d}{:10d}{:10.2f}{:10.2f}{:10.2f}".format(
cnode.m_nr, # node-number
cnode.m_inr, # internal node-number
cnode.m_kfix, # degree of freedoms
cnode.m_ncod, # additional bit code
cnode.m_xyz[0], # x coordinates
cnode.m_xyz[1], # y coordinates
cnode.m_xyz[2]) # z coordinates
# Always read the length of record before sof_cdb_get is called
# Close the CDB, 0 - will close all the files
myDLL.sof_cdb_close(0)
# Print again the status of the CDB, if status = 0 -> CDB Closed successfully
if cdbStat.value == 0:
print ("CDB closed successfully, status = 0")
