Prestressing procedure
1 or T tensioning
2 or R release
4 or W restressing
8 or S slip
The desired prestressing procedure at parameter ANWS is defined by combination of the lit-
erals T,R,S and W. The default is ”tensioning + slip = TR”. Alternatively the input can also be
given as bit-mask using numbers from 1 to 8.
- Why ”tensioning + slip = TR”? R means slip or release?
- If I use TR in PSIG, it always shows a warning:
+++++ warning no. 439 in program GSR_ANSP
Tendon 1: Given prestressing schedule at ANWS not possible. Releasing will be ignored.
- I know tensioning, release and restressing. But what’s the meaning of “slip” in ANWS?
dat file is attached.
2.dat (1.4 KB)
