I want to define a point load on SPT 1 along its local x axis,
NODE
NO
TYPE
P1
PX
2942
According to Sofiload manual
Local load directions require nodes with a local coordinate system (SOFiMSHC). Only nodes
which are input as structural points (SPT points) with a local coordinate system in SOFiMSHC
can be used here.
But it shows error:
+++++ error no. 2027 in program SL_KNOT ; input line: 42
Local coordinate system for node 1 does not exist
I think your procedure is correct. As you can see in the appended TEDDY file, your code is working. Point Load.dat (305 Bytes)
In order to repair your file, you could have a look at the local coordinate system of the structural point 1. Is the coordinate system as intended? If not, are you working with multiple SOFiMSHC or SOFiMSHA inputs? Perhaps one +prog SOFiMSHC or SOFiMSHA is remeshing the system?
