- Can variables defined by LET# and TVAR be used together? e.g.
LET#a 1
TVAR ‘b’ 2
TVAR ‘c’ ‘#a+b’
LET#d #a+‘b’
- The PRT# can print value of variable defined by LET#. Is there a similar command for TVAR?
TVAR ‘c’ ‘#a+b’
LET#d #a+‘b’
Yes you can combine variables defined by LET# and TVAR
You can use the PRT# command for a TVAR as well.
Apart from that you can use the commands TXB or TXE.
As an example you can try this code:
LET#value 1
prt#value
TVAR "help" 5
PRT#help
TXB #help
TXE #help
TVAR "LF" 6
TVAR "Formel" "=#value+5*#LF"
PRT#Formel
