I’m performing an ULTI analysis, and I achive the desired limit values of the material:
Where can I see this figure in Wingraf? The Von Mises strains are higher:
Which kind of strain does the software assume is the one that generates the failure of the structure?
Thanks and regards,
Gonzalo
JFH
2
Hello Gonzalo
The minimum averaged steel strain can be found in the following Graphic results folder:
Graphic > Results > Quadrilateral Elements > Nonlinear Results > Steel > Minimum averaged steel strain
To compare the results, you need to plot the results within the Gauss points.
Cleared up! Thank you very much!
