I have a Python script which reads some data from cdb and creates a dat file as an output. In SSD, I added a task which call the script with SYS command, but I cannot figure it out how to process the dat file created by Python script.
In other words, is it possible to process dat file created dynamically?
Hi Maksim,
I hope that I did understand you correctly. You want to run the created DAT file, right?
If yes β then just include it with +APPLY after SYS.
See following small example where temp.dat is being created from datetime.ps1 script and with APPLY it is then calcualted.
$ Get current time and date
+SYS powershell β& .\datetime.ps1β
+APPLY βtemp.datβ
The code snippet can be found on my blog: Utilizing the SYS input in SOFiSTiK FEA β BAUTUK
Kind regards,
Smiljan
