Hello everyone,
I am encountering an issue with the following part of my Teddy script:
As you can see, I start a loop at the end which should increase #i0 from 0 to 2000 (which is #number_of_timesteps). However, it seems that the variable #number_of_timesteps is always overwritten by the value I fill in for the variable #number_of_timesteps_in_impulse_buildoff, which is currently 50. As such, if I run the script as it is now, the loop would only repeat 50 times.
In short: the variable #number_of_timesteps seems to be overwritten when #number_of_timesteps_in_impulse_buildoff is defined. The variable isn’t overwritten or anything later in the script. Of course I can use a different variable name that isn’t so similar, but I’d still love to know what the exact cause of this problem is, so I can actively avoid it in the future. Is this a known bug, or am I doing something wrong?
Kind regards
