I need help with processing results in sofistik. I am still relatively new in using the software. The load case identifier for this text file (see attached) is gonna be around loadcase 900 (base 900) right? I am trying to see results for this combinations. Also see the results attached I think it is, with a red border. Just for Min My.
r.
Yes, if you specify BASE (e.g., 900), the LC number where the envelope calculation results will be stored will be a new LC such that LC_new = BASE + default LC.
The default LCs are given in the following guide excerpt.
However, there are three options for defining the LC numbers in which the envelope results will be stored. See the following excerpt:
I hope I was able to help. If you have any further questions, feel free to ask!
OMRI.
It makes so much sense. Thanks a lot!
