Hello everyone.
I am making a modal analysis with a lot of dynamic loads. The issue is If I a need a load case number bigger than 10000, the prog dyna returns an error. I was wondering if possible to make bigger this limit may be modifying some parameter or something like this. Please if anyone know how to do that I would really appreciate the support.
Could you please show me the error message, and/or upload your project files?
Until now I have never tried to use more than 10,000 load cases for a modal analysis in dyna.
I would be interested if you found a solution to this problem (“issues when having load case numbers bigger than 10.000) as I’m facing a similar problem.
I generated load cases in ‘sofiload’ (number of load cases > 10.000), calculated them in ‘ase’ and then I wanted to get results for cross section in ‘sir’. In the last step, I got an error message. This is probably because I too have more than 10.000 load cases.
Maybe you have already found a solution for this problem …
As far as I know it should be possible to use more than 10.000 loadcases in DYNA or ASE. But I heard of a problem with a loop of more than 9.999 repetitions. Perhaps this could be a reason for your problem?
If not, could you please show me the error message?
