I’m quite new wo Sofistik and i’m using Material Nr. 4 in my project and I would like it to consider it a non-linear material. I’ve taken a look at the examples (nonlinear beam, etc.) but I don’t find or understand the solution.
These are my materials:
$SOFiSTiK Export Version 4.0.580
$Automatically generated File of ASCII Export
$ Exported by AQUA Version 19.00-70
PROG AQUA
HEAD
UNIT 5
NORM ‘DIN’ ‘en199x-200x’ COUN 49 WIND ‘2’ SNOW ‘1’ WCAT ‘B’ UNIT 5
CONC 1 C ‘20’ GAM 0 TYPR B RHO 2400 TITL “=C 20/25 (EN 1992)”
SSLA EPS SERV SIG 1.500000[-] TYPE LIM
SSLA EPS ULTI SIG 1.500000[-] TYPE LIM
SSLA EPS CALC SIG -1.300000[-] TYPE LIM
HMAT 1 TYPE FOUR NSP 0.030000 A 1
MASO 4 ‘CL:1’ 2 MCLA ‘II’ FK 2.080000 FB 2.080000 FM 2.080000 FVK0 0 FT 0 FTB 0 SCM 2 E 2794 G 50 MUE 0 GAM 17.90000 ALFA 5.00000E-06 TITL “=Gusslehm”
HMAT 4 TYPE FOUR NSP 0 A 1
TIMB 5 PLY ‘40:1’ EP 9000 G 400 QH 0 GAM 5.300000 ALFA 0 SCM 1.300000 FM 32 FT0 22 FT90 5 FC0 30 FC90 9 FV 1.100000 FVR 4.600000 FVB 0 FM90 8 KMOD 0.600000 KMO1 0.700000 KMO2 0.800000 KMO3 0.900000 KMO4 1.100000 KDEF 0.600000 TITL $$
“=Furnierschichtholz”
SSLA EPS ULTI SIG 1.300000[-] TYPE LIM
HMAT 5 TYPE FOUR NSP 0.100000 A 1
STEE 7 B ‘500B’ TMAX 32 TITL “=B 500 B (EN 1992)”
SSLA EPS SERV SIG 1.150000[-] TYPE EXT
SSLA EPS ULTI SIG -1.150000[-] TYPE EXT
SSLA EPS CALC SIG -1.300000[-] TYPE EXT
HMAT 7 TYPE FOUR NSP 0 A 1
And these are my loadcases:
+PROG SOFILOAD urs:30.1
KOPF Lastdefinition
LF 1 typ g fakg 1.0
LF 2 typ g
area ref sar 1004 proj N typ PZZ p1 -1.5
area ref sar 1005 proj N typ PZZ p1 -1.5
area ref sar 1006 proj N typ PZZ p1 -1.5
area ref sar 1007 proj N typ PZZ p1 -1.5
LF 10 Typ q
area ref sar 1004 proj N typ PZZ p1 -2.8
LF 11 Typ q
area ref sar 1005 proj N typ PZZ p1 -2.8
LF 12 Typ q
area ref sar 1006 proj N typ PZZ p1 -2.8
LF 13 Typ q
area ref sar 1007 proj N typ PZZ p1 -2.8
LF 100 typ q BEZ ‘1.35G + 1.5Q1’
Copy 1 1.35
Copy 2 1.35
Copy 10 1.50
Copy 11 1.50
Copy 12 1.50
Copy 13 1.50
LF 101 typ q BEZ ‘1.35G + 1.5Q1’
Copy 1 1.35
Copy 2 1.35
Copy 10 1.50
Copy 11 1.50
LF 102 typ q BEZ ‘1.35G + 1.5Q1’
Copy 1 1.35
Copy 2 1.35
Copy 10 1.50
Copy 12 1.50
STEU WARN 197
ENDE
I’m aware of the two languages I use, but I couldn’t find a way to translate the code.
Thank’s for any hint ![]()
Regards,
Sofim
