I’m making my first model with BRIC elements and I’ve noticed a thing I can’t seem to figure out.
When I create BRIC elements it’s possible to subdivide each edge using the N, N and K option which will introduce a series of new nodes. If I know the coordinate of a node, is it possible to lookup the node number, so I can apply a support condition to that node?
Below is a minimal example illustrating the issue.
The generated nodes get incrementing node numbers, so it’s hard to know what node to add a support condition to “dynamically”.
Thanks in advance, hope someone can help
+PROG AQUA urs:23.2
HEAD Material and System generation
UNIT 5
NORM NDC 'EN199X-200X'
ECHO MAT,SECT FULL
CONC 1 C 30
STEE 3 S 500
MATE 9 E 33000 MUE 0.2 TITL 'LADE C30 SLS fcm 38 fctk 2.03'
NMAT 9 'LADE' P1 4353041 P2 1.5 P3 2028 P6 0.2 $ P3=tensile strength
+PROG SOFIMSHA urs:23.1 $ Text Input for Modeling
HEAD Text Input for Modeling
CTRL NODE 1000 ; CTRL GTOL 0.020 $ 20 mm tolerance for nodes
SYST SPAC GDIV 50000 GDIR NEGZ
UNIT 5
NODE NO 100001 X 0 Y 0 Z 0
NODE NO 100002 X 0 Y 0 Z 1
TRAN NODE FROM 100001 TO 100099 DNO 100 DY 1
TRAN NODE FROM 100001 TO 109999 DNO 10000 DX 1
BRIC N1 100001 110001 110101 100101 N5 100002 110002 110102 100102 M 4 N 4 K 4 MNO 9
NODE NO 110184 FIX PP
NODE NO 110186 FIX PP
NODE NO 110190 FIX PP
NODE NO 110192 FIX PP
+PROG SOFILOAD urs:24.1 $ Text Input for Loads
HEAD Text Input for Loads
LC 1 TYPE G TITL 'self-weight' FACD 1.0
+PROG ASE urs:2
HEAD Calculation of forces
PAGE UNII 0
CTRL OPT WARP VAL 0
SYST PROB NONL NMAT YES TOL -10.0
LC 1
