Hi! I’m trying to work on a moving spring to simulate at the end a car on a bridge. I’ve watched teh cideos online and took these files as reference:
- movs_car_collision
- movs_train_interaction
- step_intelligent_load
The problem is that when i open them with student version sofistik 2023, i see something wrong in the visualization, is not the same as the one in the online video. You can see that the barrier is hit but the car is not there.
Has it happened to you? did you get how to fix it?
Thank you in advance,
Giorgia
with version 2023 servicepack 11 it’s working. Perhaps you use an older version? Please make an Update with SAM (SOFiSTiK Application Manager).
Jost
Hi JE! No, unfortunately it continues not to work properly. More in particular, * step_intelligent_load seems to be ok, but the other two display the same problems as before. Like the car and the train move back and forth while they should move along.
I can confirm the same problem. Obviously is something wrong.
I have Service Pack 2024-0 Build 123, nonstuden version.
